فن کولر مستر CM Storm Force 200 Red LED
Cooler Master CM Storm Force 200 Red LED
گارانتی عادی
کد کالا: Lion-Product-3100
With the constant development of hardware getting better and better, the energy consumption of your computer rises because you want to get the full performance. Due to this the heat increases and so the requirements of your fan rise as well. To integrate several fans is not the right solution because your computer will get very, very noisy. Bigger fans are the optimal solution for modern high-tech systems. The CM Storm Force fan has a diameter of 200mm and so it has a displacement volume of 184 m3/h - twice the volume of 140mm fans.
  • Long life sleeve bearing for longer life expectancy
  • Silent operation for excellent case cooling
  • RoHS compliance for protecting the environment
  • LED on/off function
Model
Brand
COOLER MASTER
Model
R4-LUS-10AB-GP
Spec
Type
Case Fan
Compatibility
Case
Fan Size
200mm
Bearing Type
Sleeve
RPM
1000 RPM
Air Flow
142 CFM
Noise Level
17 - 23 dBA
Power Connector
2 Pin + Molex
LED
Blue
Physical Spec
Dimensions
200 x 200 x 30 mm
Features
Features
It only fits on Cooler Master Sniper case (11-119-194)
LED on/off function
فن - خنک کننده ها
Cooler Master
نوع کاربری
فن کیس
ابعاد فن
200 میلی‌متر
